Hi, I have been looking at various places on how to export individual clips on macro, but I am having difficulties…
I have several audio files and I would like to apply sound finder, and then export the founded sound as individual clips.
e.g.) audio-1.mp3, audio-2.mp3, audio-3.mp3 each has 5 sounds separated by sound finder, and I would like to export them as individual clips. (For this example, it’s 5 sound, but each audio files have various number of sounds.
You could make 5 copies of each file, and have the first macro find the first sound, etc.
For the general case I do not think you can do this with macros. The “Export as MP3” command does not take parameters and is going to export to the “macro-output” subdirectory using the filename of your original file, so there is going to be a one-to-one relationship. Also, currently you cannot loop within macros.
I am not sure, but you might be able to do this with nyquist or with mod-script-pipes. Good luck !
