Macro export function
Continuing the discussion from Macro setting problem - Voice Recorder mp3 file conversion:
Thanks for your advice.
Do you know how to set the export of an mp3 file so that the export takes the name of the file ? I can’t see how to do it.
Otherwise Audacity saves this every time under “export.mp3” that is the files, if there are several, are overwritten. Or you have to enter the name each time manually…which is again time-consuming with many files and no longer “automatically”…
I answered this in the old thread here: Macro setting problem - Voice Recorder mp3 file conversion - #5 by jademan
