Macro Confusion
I sing bass in a chorus and am trying to create a macro to emphasize the bass voice in choral recordings and attenuate the other voices to facilitate learning the bass line. I can achieve this interactively with the “Filter Curve EQ”.
However, the functions that I find in the Macro Manager look nothing like those that I see in the interactive UI, e.g under Effect - EQ and Filters. How should I go about this?
Also, the relevant functions in the Macro Manager offer only
Use Preset=”<Current Settings>”
Where can I set the “Current Settings”? Are other “Presets” possible? If so, how?
I would also like the output files to be stored in the source directory or a subdirectory thereof, but find no way to do this in the documentation. Is there a way to base the output directory on the input directory? if so, how?
Please excuse the post before reading all the documentation. After reading the Scripting Reference and Macros Palette articles, I reexamined the functions in the Macro Manager and found “Filter Curve EQ”. The “Current Preset” contained the curve I had used interactively, so that satisfies my immediate needs.
Even after reading “Manage Presets” I was unable to figure out how to use presets for filters like “3 Band EQ* that I didn’t find in the interactive UI, but this isn’t an immediate priority for me.
I would still like to use a subdirectory of the source directory for exports; I will post a feature request.
P.S. After further research, I see that this was a feature in previous versions of Audacity that was eliminated a few years ago. Instead of a feature request, I have added a comment in github:
