macos10.8.5
BTW, does this link still work?
http://www.kozco.com/tech/LRMonoPhase4.wav
This mac,os10.8.5 has itunes installed, is there a way to use that app to convert songs to mp3 format?
It does for me.
See Missing features - Audacity Support .
Please note we can’t answer detailed questions about iTunes.
Many of the iTunes tools and converters stop working if you have downloaded protected songs. There is an under-the-table way around that by making a playlist, put the song in it and then burn the playlist to an Audio CD. Then rip the CD back into iTunes and iTunes will volunteer to convert the import to anything you want that QuickTime can handle – including MP3.
And yes, my test sound clips work just fine.
