Mac 10.6.8
How do I export an aiff file created in Audacity to Itunes 11.4?
Export either AIFF or WAV (cousins of each other) to the desktop. Control-Click on the sound file > Open With: iTunes. iTunes import settings are where you can change the file type (if you need to). iTunes > Preferences > General > CD Import > Import Settings.
Thanks very much. I’ll give it a try.
Larry
And see this workflow tutorial from the Manual: http://manual.audacityteam.org/o/man/sample_workflow_for_exporting_to_itunes.html
