Hello everybody,
I would like to know how to load lv2 plugins in Audacity and make them work. In particular I use Audacity 1.3.5 Beta Version on a Linux system.
Thank you very much
giodum
Hello everybody,
Thank you very much
giodum
You don’t. 1.3.5 is obsolete and doesn’t support lv2. I suggest you compile from the current 1.3.12 source tarball (or SVN HEAD) and compile with USE_SLV2 defined and libslv2 enabled.
