Hi all,
sorry if this has already been discussed, but I can’t find a discussion with the exact same problem as i have.
I was recording a mix from regular DJ CDJ’s and Behringer Mixer, using a Behringer UFO202 audio interface USB to connect the output of my mixer to the input of my laptop.
When starting to record, I noticed that I had to bring the MIC level down to around 0.10, or else I would have a really distorted sound, and the recording level would be way over -12 to -6, which are the recommended levels.
This seemed very low to me. After recording, I normalised and amplified my mix to get my output volume up a bit, but even after exporting it as WAV of MP3, the output volume was low, I would say around 50% of what it should be, if I compare it to other volumes played at my pc.
I noticed that the wave-form wasn’t as high as it could be when recording (maybe round 70%), which probably results in the huge volume difference. But if I change gain or master volumes on my mixer, or the MIC level to boost the volume up, the sound becomes distorted because of the recording level being too high.
I’ve been searching for possible solutions, tried different settings, etc, but nothing really helped.
So I would REALLY appreciate it if someone came with a solution
Thanks in advance, and sorry for possible mistakes in my English.
Here is a mix I made, where you could notice the low volume.
https://www.youtube.com/watch?v=wUES-K715lY
Greets
