lost long session
Hi,
I recorded a 2 hour interview on my macbook (10.7.5.) and thought I saved it, but I can not find the file. I have found various files with some of the info in folders (d05;d06) called e005481.au; e005a0f.au but they are each in 6 sec (1.1MB) sections, and each time I try to move them into audacity it fails and audacity closes.
I am very tired and frustrated now, and do not program computers, so please type slowly:)
  1. what is the best way to recover these files
  2. how do I get them back together as one, piecing together 6 sec parts of a two hour interview is not going to work
  3. why does the app keep shutting down?
  4. I have another interview this afternoon, how do I prevent this from occuring? can I save things as I’m recording?
Don’t touch those! That is the audio data that is used by the project (the recording).
Those files should be nested in a folder inside another folder - navigate back out from that folder an you should find that they are in a folder that ends with “_data”.
The first part of that folder name is the name that you used to save the project. So, for example, if that folder is called “fish_data”, then the project was saved with the name “fish”. Whatever name was used, look for a file, in the same location as that project folder, that has the same name - it will have a file extension “.aup” (the file extension will probably be hidden by Windows). So, coming back to the example, if the data folder was in “Documents” and was called “fish_data”, then you are looking for a file that is also in “Documents” (or wherever the data folder is) and is also called “fish” (or whatever name the data folder has).
I may have found it. It was titled in hebrew (my som must have been working on something). not sur if it’s the whole thing. looks like 241 KB. but when ever I try to open it, audacity shuts down. here is the message:
Process:         Audacity [2696]
Path:            /Applications/Audacity/Audacity.app/Contents/MacOS/Audacity
Identifier:      net.sourceforge.audacity
Version:         2.0.3.0 (2.0.3.0)
Code Type:       X86 (Native)
Parent Process:  launchd [144]
Date/Time:       2013-05-11 08:50:58.291 -0700
OS Version:      Mac OS X 10.7.5 (11G63)
Report Version:  9
Interval Since Last Report:          311959 sec
Crashes Since Last Report:           12
Per-App Interval Since Last Report:  209739 sec
Per-App Crashes Since Last Report:   11
Anonymous UUID:                      D7605852-5B21-46EB-8F49-CCE9DAD8A6C6
Crashed Thread:  0  Dispatch queue: com.apple.main-thread
Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00000000448c800c
VM Regions Near 0x448c800c:
    MALLOC_LARGE           00000000347b8000-00000000348a5000 [  948K] rw-/rwx SM=PRV
    __TEXT                 0000000070000000-0000000070142000 [ 1288K] r-x/rwx SM=COW  /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
Application Specific Information:
objc[2696]: garbage collection is OFF
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   com.apple.QD                  	0x958d302f TTextLineLayout::PrepareForWriteUse() + 43
1   com.apple.QD                  	0x958d3112 PrepareTextLayoutForUse(unsigned char, OpaqueATSUTextLayout*, TTextLineLayout**) + 34
2   com.apple.QD                  	0x958d314a PrepareInitializedTextLayoutForUse(unsigned char, OpaqueATSUTextLayout*, TTextLineLayout**) + 34
3   com.apple.QD                  	0x958b7818 ATSUSetTransientFontMatching + 34
4   Audacity                      	0x003fb756 wxMacCoreGraphicsContext::DrawText(wxString const&, double, double, double) + 310
5   Audacity                      	0x003f8cb2 wxMacCoreGraphicsContext::DrawText(wxString const&, double, double) + 66
6   Audacity                      	0x00474516 wxDC::DoDrawText(wxString const&, int, int) + 310
7   Audacity                      	0x0042af64 wxStatusBar::DrawFieldText(wxDC&, int) + 404
8   Audacity                      	0x0042b29f wxStatusBar::OnPaint(wxPaintEvent&) + 671
9   Audacity                      	0x0058fc83 wxEvtHandler::ProcessEventIfMatches(wxEventTableEntryBase const&, wxEvtHandler*, wxEvent&) + 115
10  Audacity                      	0x0058fdff wxEventHashTable::HandleEvent(wxEvent&, wxEvtHandler*) + 111
11  Audacity                      	0x005901cf wxEvtHandler::ProcessEvent(wxEvent&) + 207
12  Audacity                      	0x00447352 wxWindow::MacDoRedraw(void*, long) + 1218
13  Audacity                      	0x00445a2b wxMacWindowControlEventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1211
14  Audacity                      	0x00446143 wxMacWindowEventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 339
15  com.apple.HIToolbox           	0x98989c0c _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
16  com.apple.HIToolbox           	0x98805313 _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 1602
17  com.apple.HIToolbox           	0x98804790 _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCallRec + 482
18  com.apple.HIToolbox           	0x988045a8 SendEventToEventTargetWithOptions + 75
19  com.apple.HIToolbox           	0x98825040 HIView::SendDraw(short, OpaqueGrafPtr*, __HIShape const*, CGContext*) + 478
20  com.apple.HIToolbox           	0x988b3b9f HIView::RecursiveDrawComposited(__HIShape const*, __HIShape const*, unsigned long, HIView*, CGContext*, unsigned char, float) + 755
21  com.apple.HIToolbox           	0x988b3e91 HIView::RecursiveDrawComposited(__HIShape const*, __HIShape const*, unsigned long, HIView*, CGContext*, unsigned char, float) + 1509
22  com.apple.HIToolbox           	0x988b3e91 HIView::RecursiveDrawComposited(__HIShape const*, __HIShape const*, unsigned long, HIView*, CGContext*, unsigned char, float) + 1509
23  com.apple.HIToolbox           	0x988b4e43 HIView::DrawComposited(short, OpaqueGrafPtr*, __HIShape const*, unsigned long, HIView*, CGContext*) + 1227
24  com.apple.HIToolbox           	0x988b4f8b HIView::Draw(short, OpaqueGrafPtr*, unsigned long) + 81
25  com.apple.HIToolbox           	0x988b5353 HIView::Render(unsigned long, CGContext*) + 45
26  com.apple.HIToolbox           	0x98814e97 _ZL17FlushWindowObjectP10WindowDataPPvh + 736
27  com.apple.HIToolbox           	0x98824bc7 _FlushWindow + 70
28  com.apple.HIToolbox           	0x98824b70 HIWindowFlush + 29
29  Audacity                      	0x0043b431 wxTopLevelWindowMac::MacPerformUpdates() + 161
30  Audacity                      	0x0042ad9f wxStatusBar::SetStatusText(wxString const&, int) + 223
31  Audacity                      	0x0019b437 AudacityProject::Save(bool, bool, bool) + 1095
32  Audacity                      	0x001a0371 AudacityProject::OnCloseWindow(wxCloseEvent&) + 2401
33  Audacity                      	0x0058fc83 wxEvtHandler::ProcessEventIfMatches(wxEventTableEntryBase const&, wxEvtHandler*, wxEvent&) + 115
34  Audacity                      	0x0058fdff wxEventHashTable::HandleEvent(wxEvent&, wxEvtHandler*) + 111
35  Audacity                      	0x005901cf wxEvtHandler::ProcessEvent(wxEvent&) + 207
36  Audacity                      	0x004d921e wxWindowBase::Close(bool) + 110
37  Audacity                      	0x0043e125 wxMacTopLevelEventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 3861
38  com.apple.HIToolbox           	0x98989c0c _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
39  com.apple.HIToolbox           	0x98805313 _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 1602
40  com.apple.HIToolbox           	0x98804790 _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCallRec + 482
41  com.apple.HIToolbox           	0x98819571 SendEventToEventTarget + 76
42  com.apple.HIToolbox           	0x988fc142 HIWindowButtonView::SendWindowEvent(unsigned long, unsigned long) + 208
43  com.apple.HIToolbox           	0x988fcb79 HIWindowButtonView::ControlHitSelf(OpaqueControlRef*, short, unsigned long) + 69
44  com.apple.HIToolbox           	0x98820396 HIView::EventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 9262
45  com.apple.HIToolbox           	0x98989c0c _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
46  com.apple.HIToolbox           	0x98805313 _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 1602
47  com.apple.HIToolbox           	0x98804790 _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCallRec + 482
48  com.apple.HIToolbox           	0x98819571 SendEventToEventTarget + 76
49  com.apple.HIToolbox           	0x988b0450 SendControlHit(HIView*, OpaqueEventRef*, short, unsigned long) + 296
50  com.apple.HIToolbox           	0x988a8041 HIView::NotifyControlHit(OpaqueEventRef*, short, unsigned long) + 41
51  com.apple.HIToolbox           	0x988a8198 HIView::ClickInternal(CGPoint const&, unsigned long, void (*)(OpaqueControlRef*, short), OpaqueEventRef*, bool) + 258
52  com.apple.HIToolbox           	0x988a832b HIView::ClickSelf(OpaqueEventRef*) + 381
53  com.apple.HIToolbox           	0x988fcb32 HIWindowButtonView::ClickSelf(OpaqueEventRef*) + 230
54  com.apple.HIToolbox           	0x9881ea43 HIView::EventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 2779
55  com.apple.HIToolbox           	0x98989c0c _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
56  com.apple.HIToolbox           	0x98805313 _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 1602
57  com.apple.HIToolbox           	0x98804790 _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCallRec + 482
58  com.apple.HIToolbox           	0x98819571 SendEventToEventTarget + 76
59  com.apple.HIToolbox           	0x988a8468 HIView::Click(OpaqueEventRef*) + 306
60  com.apple.HIToolbox           	0x988a853d HIViewClick + 54
61  com.apple.HIToolbox           	0x98995d8e _ZL19HandleClickAsHIViewP15OpaqueWindowPtrP14OpaqueEventRef + 149
62  com.apple.HIToolbox           	0x98996103 _ZL17HandleWindowClickP15OpaqueWindowPtr5PointsmP14OpaqueEventRef + 504
63  com.apple.HIToolbox           	0x98996489 _ZL16HandleMouseEventP25OpaqueEventHandlerCallRefP14OpaqueEventRef + 850
64  com.apple.HIToolbox           	0x98996a11 _ZL26StandardWindowEventHandlerP25OpaqueEventHandlerCallRefP14OpaqueEventRefPv + 79
65  com.apple.HIToolbox           	0x98989c0c _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
66  com.apple.HIToolbox           	0x98805313 _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 1602
67  com.apple.HIToolbox           	0x98804790 _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCallRec + 482
68  com.apple.HIToolbox           	0x98819571 SendEventToEventTarget + 76
69  com.apple.HIToolbox           	0x98819d27 _ZL29ToolboxEventDispatcherHandlerP25OpaqueEventHandlerCallRefP14OpaqueEventRefPv + 1969
70  com.apple.HIToolbox           	0x988057ce _ZL23DispatchEventToHandlersP14EventTargetRecP14OpaqueEventRefP14HandlerCallRec + 2813
71  com.apple.HIToolbox           	0x98804790 _ZL30SendEventToEventTargetInternalP14OpaqueEventRefP20OpaqueEventTargetRefP14HandlerCallRec + 482
72  com.apple.HIToolbox           	0x98819571 SendEventToEventTarget + 76
73  Audacity                      	0x003d8bf6 wxApp::MacHandleOneEvent(void*) + 38
74  Audacity                      	0x003d8ccf wxApp::MacDoOneEvent() + 127
75  Audacity                      	0x003f16a3 wxEventLoop::Dispatch() + 35
76  Audacity                      	0x0048438f wxEventLoopManual::Run() + 111
77  Audacity                      	0x0045e5d3 wxAppBase::MainLoop() + 83
78  Audacity                      	0x0053eeea wxEntry(int&, wchar_t**) + 154
79  Audacity                      	0x0003e6a8 main + 24
80  Audacity                      	0x0003e44e _start + 216
81  Audacity                      	0x0003e375 start + 41
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0   libsystem_kernel.dylib        	0x92f0690a kevent + 10
1   libdispatch.dylib             	0x99134e04 _dispatch_mgr_invoke + 969
2   libdispatch.dylib             	0x99133853 _dispatch_mgr_thread + 53
Thread 2:
0   libsystem_kernel.dylib        	0x92f03d36 mach_wait_until + 10
1   libsystem_c.dylib             	0x99a31439 nanosleep + 388
2   Audacity                      	0x0004f754 AudioThread::Entry() + 100
3   libsystem_c.dylib             	0x99a83ed9 _pthread_start + 335
4   libsystem_c.dylib             	0x99a876de thread_start + 34
Thread 3:: com.apple.CFSocket.private
0   libsystem_kernel.dylib        	0x92f05b42 __select + 10
1   com.apple.CoreFoundation      	0x90898e15 __CFSocketManager + 1557
2   libsystem_c.dylib             	0x99a83ed9 _pthread_start + 335
3   libsystem_c.dylib             	0x99a876de thread_start + 34
Thread 4:
0   libsystem_kernel.dylib        	0x92f0602e __workq_kernreturn + 10
1   libsystem_c.dylib             	0x99a85ccf _pthread_wqthread + 773
2   libsystem_c.dylib             	0x99a876fe start_wqthread + 30
Thread 5:
Thread 0 crashed with X86 Thread State (32-bit):
  eax: 0x00000000  ebx: 0xac6981d0  ecx: 0x00002000  edx: 0x1a2ce000
  edi: 0x448c8000  esi: 0xffffdd97  ebp: 0xbfffcb58  esp: 0xbfffcb40
   ss: 0x00000023  efl: 0x00010246  eip: 0x958d302f   cs: 0x0000001b
   ds: 0x00000023   es: 0x00000023   fs: 0x00000000   gs: 0x0000000f
  cr2: 0x448c800c
Logical CPU: 0
Binary Images:
    0x1000 -   0xaa6fe7 +Audacity (??? - ???) <432D620E-B299-E7F8-BB23-54A599E23A09> /Applications/Audacity/Audacity.app/Contents/MacOS/Audacity
 0x108f000 -  0x10dbffb  com.apple.audio.midi.CoreMIDI (1.8 - 42) <67FE17BA-C921-3D2D-AAC5-B5E9083CE004> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
 0x117b000 -  0x117cff1  com.apple.textencoding.unicode (2.4 - 2.4) <4E55D4B9-4E67-3FC9-9407-3E99D1D50F15> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
 0x1196000 -  0x119afff  com.apple.CommonCocoaPanels (4.0 - 16) <06AC4327-17DD-37FB-84EA-B7BA94F3C43D> /System/Library/CoreServices/CommonCocoaPanels.bundle/Contents/MacOS/CommonCocoaPanels
 0x17e1000 -  0x17e5ffb  com.apple.audio.AudioIPCPlugIn (1.2.3 - 1.2.3) <D4092467-5BBE-3ED6-A493-7DB1EE8E6686> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
 0x17ea000 -  0x17effff  com.apple.audio.AppleHDAHALPlugIn (2.2.5 - 2.2.5a5) <BAD1E0E6-10E6-342C-BEB8-B1706F0CE2CF> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
 0x39a5000 -  0x39aeff6  libcldcpuengine.dylib (2.0.19 - compatibility 1.0.0) <95A88DC8-E5EE-363F-9275-214D5AB7A2EF> /System/Library/Frameworks/OpenCL.framework/Libraries/libcldcpuengine.dylib
 0x39b5000 -  0x39b7fff  libCoreFSCache.dylib (??? - ???) <9E7CBE71-566C-36E9-A49F-C5FF6956D76F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
 0x39bf000 -  0x39bfffd +cl_kernels (??? - ???) <5500BAC2-898E-46F9-BBD6-2D353284F24D> cl_kernels
 0x3b89000 -  0x3b8cfef  com.apple.LiveType.component (2.1.3 - 2.1.3) /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
 0x7508000 -  0x756dfde  com.apple.LiveType.framework (2.1.3 - 2.1.3) /System/Library/PrivateFrameworks/LiveType.framework/Versions/A/LiveType
 0xd557000 -  0xd5ffff7  unorm8_bgra.dylib (2.0.19 - compatibility 1.0.0) <99A967D2-5577-396B-BD11-56EAFF962AB2> /System/Library/Frameworks/OpenCL.framework/Libraries/ImageFormats/unorm8_bgra.dylib
0x70000000 - 0x70141fff  com.apple.audio.units.Components (1.7.3 - 1.7.3) <288826E4-A704-3FDB-8DF6-AFD50A73142B> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x8fe11000 - 0x8fe43aa7  dyld (195.6 - ???) <3A866A34-4CDD-35A4-B26E-F145B05F3644> /usr/lib/dyld
0x90134000 - 0x90195ffb  com.apple.audio.CoreAudio (4.0.3 - 4.0.3) <7A14BE52-6789-3CE3-9AE9-B733F4903EB1> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x901a2000 - 0x901abff3  com.apple.CommonAuth (2.2 - 2.0) <C3FD6EC2-8EB3-38FB-BBB7-05009CA49024> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x901ac000 - 0x901ceff8  com.apple.PerformanceAnalysis (1.11 - 11) <453463FF-7C42-3526-8C96-A9971EE07154> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x901cf000 - 0x901dffff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <6D6F0C9D-2EEA-3578-AF3D-E2A09BCECAF3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x9023d000 - 0x902b3fff  com.apple.Metadata (10.7.0 - 627.37) <F54AED70-95C5-3561-8C87-D9E5539E98A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x902b4000 - 0x902daffb  com.apple.quartzfilters (1.7.0 - 1.7.0) <64AB163E-7E91-3028-8730-BE11BC1F5237> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x902db000 - 0x902e1ffb  com.apple.print.framework.Print (7.4 - 247.3) <CB075EEE-FA1F-345C-A1B5-1AB266FC73A1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x902e2000 - 0x902e4ffb  libRadiance.dylib (??? - ???) <4721057E-5A1F-3083-911B-200ED1CE7678> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x902e5000 - 0x90347ffb  com.apple.datadetectorscore (3.0 - 179.4) <3A418498-C189-37A1-9B86-F0ECB33AD91C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x90348000 - 0x90350ff3  liblaunch.dylib (392.39.0 - compatibility 1.0.0) <9E6135FF-C2B1-3BC9-A160-B32D71BFA77C> /usr/lib/system/liblaunch.dylib
0x9036f000 - 0x9037cfff  com.apple.HelpData (2.1.2 - 72.2) <330C6B7F-2512-37B7-B2FF-24E1804E9426> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x9037d000 - 0x9040afe7  libvMisc.dylib (325.4.0 - compatibility 1.0.0) <F2A8BBA3-6431-3CED-8CD3-0953410B6F96> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x90416000 - 0x90525ff7  com.apple.DesktopServices (1.6.5 - 1.6.5) <CEC069D7-37A3-3D25-A3BB-39DE99FDA46E> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x90526000 - 0x90530ff0  com.apple.DirectoryService.Framework (10.7 - 146) <59061A4B-D743-3A34-B142-7BE2472BBC2D> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x90531000 - 0x9055fff7  com.apple.DictionaryServices (1.2.1 - 158.3) <8D03D180-D834-39F3-A106-78E0B22A7893> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x90658000 - 0x906c7fff  com.apple.Heimdal (2.2 - 2.0) <2E1B8779-36D4-3C62-A67E-0034D77D7707> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x906c8000 - 0x906ddff7  com.apple.ImageCapture (7.1.0 - 7.1.0) <E5FCA336-7E47-343E-A82D-CCCA5BCD5929> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x906de000 - 0x90726ff7  com.apple.SystemConfiguration (1.11.3 - 1.11) <68B92FEA-F754-3E7E-B5E6-D512E26144E7> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x90727000 - 0x9073eff8  com.apple.CoreMediaAuthoring (2.0 - 891) <69D569FD-670C-3BD0-94BF-7A8954AA2953> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x90753000 - 0x907ddffb  com.apple.SearchKit (1.4.0 - 1.4.0) <CF074082-64AB-3A1F-831E-582DF1667827> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x907de000 - 0x90809fff  com.apple.GSS (2.2 - 2.0) <2C468B23-FA87-30B5-B9A6-8C5D1373AA30> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x9080a000 - 0x9080dffd  libCoreVMClient.dylib (??? - ???) <B8F8916D-F12A-3D95-ABF3-999D57B7D581> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x9080e000 - 0x9080efff  com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <22997C20-BEB7-301D-86C5-5BFB3B06D212> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x9080f000 - 0x909e6fe7  com.apple.CoreFoundation (6.7.2 - 635.21) <4D1D2BAF-1332-32DF-A81B-7E79D4F0A6CB> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x909f6000 - 0x9148bff6  com.apple.AppKit (6.7.5 - 1138.51) <B9D3DCA0-9765-354E-9730-75A45A97DDFD> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x9148c000 - 0x91493ff7  libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <47DB9E1B-A7D1-3818-A747-382B2C5D9E1B> /usr/lib/system/libsystem_notify.dylib
0x91494000 - 0x914c8ff3  libTrueTypeScaler.dylib (??? - ???) <C2D2257F-11E6-336C-BBA8-934BD9214728> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x914c9000 - 0x914fdff8  libssl.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <567E922C-E64F-321B-9A47-6B18BF481625> /usr/lib/libssl.0.9.8.dylib
0x914fe000 - 0x91509ffe  libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0) <B63F5D07-93B3-3F02-BFB7-472B4ED3521F> /usr/lib/libbz2.1.0.dylib
0x91db4000 - 0x91dd0ff1  libPng.dylib (??? - ???) <F084226B-14F0-36C0-B5EC-22C78406D2B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x91e12000 - 0x91e3aff7  libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <AB530FB2-8BD1-3328-95E8-CF449F0429CA> /usr/lib/libxslt.1.dylib
0x91e3b000 - 0x91f59fec  com.apple.vImage (5.1 - 5.1) <7757F253-B281-3612-89D4-F2B04061CBE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x91f5a000 - 0x9210eff3  libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <4AFF6FC3-6283-3934-8EFC-CA227CA11164> /usr/lib/libicucore.A.dylib
0x9210f000 - 0x92118fff  libc++abi.dylib (14.0.0 - compatibility 1.0.0) <FEB5330E-AD5D-37A0-8AB2-0820F311A2C8> /usr/lib/libc++abi.dylib
0x92252000 - 0x92288ff7  com.apple.AE (527.7 - 527.7) <7BAFBF18-3997-3656-9823-FD3B455056A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x925b9000 - 0x925bcff9  libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <16DCE20A-9790-369A-94C1-B7954B418C77> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x925bd000 - 0x925e4ff3  com.apple.framework.Apple80211 (7.4.1 - 741.1) <7F29673A-B030-34AF-B8CA-AB30DD63FFAB> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x92600000 - 0x92687fff  com.apple.print.framework.PrintCore (7.1 - 366.3) <EEC03CAB-7F79-3931-87FE-4DF0B767BF47> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x92694000 - 0x926e7ff3  com.apple.ImageCaptureCore (3.1.0 - 3.1.0) <F7ACE42B-2F58-3642-9469-9CDCF31F0273> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x926e8000 - 0x926e9ffd  libCVMSPluginSupport.dylib (??? - ???) <4B0476F9-950D-3EB7-BD83-F65AF0B05F0E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x926ea000 - 0x926eeff3  libsystem_network.dylib (??? - ???) <62EBADDA-FC72-3275-AAB3-5EDD949FEFAF> /usr/lib/system/libsystem_network.dylib
0x926ef000 - 0x92711ffe  com.apple.framework.familycontrols (3.0 - 300) <6735D7ED-7053-3AB8-B144-E7F70A124CCD> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x92718000 - 0x9286efff  com.apple.audio.toolbox.AudioToolbox (1.7.3 - 1.7.3) <F09C7075-2C4E-3A4F-A372-95D700125513> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9286f000 - 0x9288bff5  com.apple.GenerationalStorage (1.0 - 126.1) <E622F823-7D98-3D13-9C3D-7EA482567394> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x928e9000 - 0x92b14ffb  com.apple.QuartzComposer (5.0 - 236.10) <416993F4-2868-35FF-90DE-34C93D83574F> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x92b15000 - 0x92c05ff1  libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <9E5F86A3-8405-3774-9E0C-3A074273C96D> /usr/lib/libiconv.2.dylib
0x92c06000 - 0x92d1dfe9  com.apple.WebKit (7534.57 - 7534.57.7) <85DAC34E-86A1-380F-B166-56630C9B0BD5> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x92d1e000 - 0x92d3bff3  com.apple.openscripting (1.3.3 - ???) <0579A4CB-FD6F-3D7F-A17B-AC0F2CF11FC7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x92d3c000 - 0x92d3fff7  libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <7F6C14CC-0169-3F1B-B89C-372F67F1F3B5> /usr/lib/system/libcompiler_rt.dylib
0x92d40000 - 0x92d87ff5  com.apple.opencl (2.0.19 - 2.0.19) <7689E7B9-EE5A-3F74-8699-4CDED9162260> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x92d88000 - 0x92e04ff3  libType1Scaler.dylib (??? - ???) <C931AA06-5086-3A0E-873B-47459AD3CDD3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
0x92e05000 - 0x92e07ff7  libdyld.dylib (195.5.0 - compatibility 1.0.0) <52F7B44C-1B43-3B7B-9C9E-6410D8682935> /usr/lib/system/libdyld.dylib
0x92e08000 - 0x92e0dff7  libmacho.dylib (800.0.0 - compatibility 1.0.0) <943213F3-CC9B-328E-8A6F-16D85C4274C7> /usr/lib/system/libmacho.dylib
0x92e0e000 - 0x92e10ff9  com.apple.securityhi (4.0 - 1) <39157216-5E43-392A-AE3F-716726D8C8BF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x92e11000 - 0x92e1efff  libGL.dylib (??? - ???) <A72F14F7-1836-34AB-9F08-67836CB966E4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x92e1f000 - 0x92e70ff9  com.apple.QuickLookFramework (3.2 - 500.18) <CF3EF345-EA3E-3C2D-B56D-E4433326254A> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x92e71000 - 0x92ea7ff4  com.apple.LDAPFramework (3.2 - 120.2) <CCEB43CD-3861-33CC-8D9B-588F415A7028> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x92ea8000 - 0x92eecff3  com.apple.framework.CoreWLAN (2.1.3 - 213.1) <8A99ADB8-4A3E-3B8E-A0E4-A39398C288EC> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x92eed000 - 0x92f0bff7  libsystem_kernel.dylib (1699.32.7 - compatibility 1.0.0) <79179F83-457A-3539-A76B-E960D2108109> /usr/lib/system/libsystem_kernel.dylib
0x92f0c000 - 0x92f0fffb  com.apple.help (1.3.2 - 42) <B1E6701C-7473-30B2-AB5A-AFC9A4823694> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x92f1f000 - 0x92f6fffa  libTIFF.dylib (??? - ???) <9511A31E-070C-313E-8320-AAB683AD0653> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x92fad000 - 0x931a5ff7  com.apple.CoreData (104.1 - 358.14) <C1730963-F75D-3338-B65F-D50235538B28> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x931a6000 - 0x931b0ff2  com.apple.audio.SoundManager (3.9.4.1 - 3.9.4.1) <2A089CE8-9760-3F0F-B77D-29A78940EA17> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x9320e000 - 0x934c0ff7  com.apple.AddressBook.framework (6.1.3 - 1091) <B8CC707C-6368-3CDD-BE38-D2335B7CC2DE> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x934c1000 - 0x93790ffb  com.apple.security (7.0 - 55148.6) <8DF67BDD-C98F-3B7E-AC63-D468407FA82D> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x93791000 - 0x937a1ff7  libCRFSuite.dylib (??? - ???) <94E040D2-2769-359A-A21B-DB85FCB73BDC> /usr/lib/libCRFSuite.dylib
0x937a2000 - 0x937a2fff  com.apple.Cocoa (6.6 - ???) <5FAFE73E-6AF5-3D09-9191-0BDC8C6875CB> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x937a3000 - 0x93800ffb  com.apple.htmlrendering (76 - 1.1.4) <409EF0CB-2997-369A-9326-BE12436B9EE1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x93801000 - 0x93a86fe3  com.apple.QuickTime (7.7.1 - 2340) <76E45D49-3D4F-32AB-A411-E52C22FA24C8> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x93a87000 - 0x93b5fff6  com.apple.QuickLookUIFramework (3.2 - 500.18) <CE281BD9-C1CF-3F87-BD22-412ED253580E> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x93e39000 - 0x93eb6fff  com.apple.PDFKit (2.6.5 - 2.6.5) <9AA55EFF-CFD5-3CC2-ACB8-C554898D872F> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x93ec3000 - 0x942c5ff6  libLAPACK.dylib (??? - ???) <00BE0221-8564-3F87-9F6B-8A910CF2F141> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x942c6000 - 0x942d4fff  libz.1.dylib (1.2.5 - compatibility 1.0.0) <E73A4025-835C-3F73-9853-B08606E892DB> /usr/lib/libz.1.dylib
0x942d5000 - 0x94395ffb  com.apple.ColorSync (4.7.4 - 4.7.4) <0A68AF35-15DF-3A0A-9B17-70CE2A106A6C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x94396000 - 0x94cc172b  com.apple.CoreGraphics (1.600.0 - ???) <DD7CDD67-FC4F-36FE-962F-2EA7EF3FC780> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x94cdb000 - 0x94db2ff3  com.apple.avfoundation (2.0 - 180.50) <7B7FDF30-AC40-3715-A409-B5A27F7B5585> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x94db3000 - 0x94df4ff9  libcurl.4.dylib (7.0.0 - compatibility 7.0.0) <9FD420FB-7984-3A07-8914-BB19E687D38B> /usr/lib/libcurl.4.dylib
0x94e36000 - 0x95140ff3  com.apple.Foundation (6.7.2 - 833.25) <4C52ED74-A1FD-3087-A2E1-035AB3CF9610> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x95154000 - 0x95456fff  com.apple.CoreServices.CarbonCore (960.25 - 960.25) <C613B0DA-B401-3DC7-B626-6E20D4DDC8A8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x9556c000 - 0x95573ff8  libCGXCoreImage.A.dylib (600.0.0 - compatibility 64.0.0) <4F9DD9D1-F251-3661-A3C6-B1F550B084B0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0x95574000 - 0x9557ffff  libkxld.dylib (??? - ???) <14E79D7A-B6C2-35C5-B56D-D343BEC2A106> /usr/lib/system/libkxld.dylib
0x95580000 - 0x955c3ffd  libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <6B35F203-5D72-335A-A4BC-CC89FEC0E14F> /usr/lib/system/libcommonCrypto.dylib
0x955cf000 - 0x9560fff7  com.apple.NavigationServices (3.7 - 193) <16A8BCC8-7343-3A90-88B3-AAA334DF615F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x95610000 - 0x95652ff7  com.apple.CoreMedia (1.0 - 705.94) <10D5D25F-9BCB-3406-B737-23D9FDF2CC71> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x956c2000 - 0x95825fff  com.apple.QTKit (7.7.1 - 2339) <163FBDDD-0458-378F-84DD-CB0F603A259E> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x95826000 - 0x95836fff  libsasl2.2.dylib (3.15.0 - compatibility 3.0.0) <D6F728DA-990A-32A3-86FA-4A3F4D88E309> /usr/lib/libsasl2.2.dylib
0x95837000 - 0x95845fff  com.apple.opengl (1.8.1 - 1.8.1) <766AFB12-A2CB-3A55-B662-FC9FFCAE0008> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x95846000 - 0x9584affa  libcache.dylib (47.0.0 - compatibility 1.0.0) <56256537-6538-3522-BCB6-2C79DA6AC8CD> /usr/lib/system/libcache.dylib
0x9584b000 - 0x958effff  com.apple.QD (3.40 - ???) <3881BEC6-0908-3073-BA44-346356E1CDF9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x95cf7000 - 0x95d11fff  com.apple.Kerberos (1.0 - 1) <D7920A1C-FEC4-3460-8DD0-D02491578CBB> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x95d12000 - 0x95d16ffd  IOSurface (??? - ???) <EDDBEE65-1EB8-33A7-9972-E361A3508234> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x95d17000 - 0x95d1dfff  libGFXShared.dylib (??? - ???) <9C9834EB-B794-38C8-9B90-31D8CB234F86> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x95d1e000 - 0x95d4cfe7  libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <30189C33-6ADD-3142-83F3-6114B1FC152E> /usr/lib/libSystem.B.dylib
0x95d61000 - 0x95d67ffd  com.apple.CommerceCore (1.0 - 17) <E59CD307-58E2-35FD-9131-B38978799910> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x95d68000 - 0x95d8bfff  com.apple.CoreVideo (1.7 - 70.3) <4234C11C-E8E9-309A-9465-27D6D7458895> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x95d8c000 - 0x96147ffb  com.apple.SceneKit (125.3 - 125.8) <89008B87-87E7-3972-A274-30311497EE32> /System/Library/PrivateFrameworks/SceneKit.framework/Versions/A/SceneKit
0x96148000 - 0x9622bff7  libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <BD913D3B-388D-33AE-AA5E-4810C743C28F> /usr/lib/libcrypto.0.9.8.dylib
0x962e3000 - 0x96303ff7  com.apple.RemoteViewServices (1.5 - 44.2) <11C87337-FF29-3976-A230-6387D96563C5> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x96304000 - 0x96344ff7  libauto.dylib (??? - ???) <984C81BE-FA1C-3228-8F7E-2965E7E5EB85> /usr/lib/libauto.dylib
0x96345000 - 0x9637cfef  com.apple.DebugSymbols (2.1 - 87) <EB951B78-31A5-379F-AFA1-B5C9A7BB3D23> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x963ca000 - 0x963dbfff  libbsm.0.dylib (??? - ???) <54ACF696-87C6-3652-808A-17BE7275C230> /usr/lib/libbsm.0.dylib
0x963dc000 - 0x96420fff  com.apple.MediaKit (12 - 602) <6E429DD7-8829-37DE-94AF-940FB70F2FB9> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x96421000 - 0x9649cffb  com.apple.ApplicationServices.ATS (317.12.0 - ???) <4D124B65-3D43-32E9-B296-3671347BB888> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x9649d000 - 0x965ffffb  com.apple.QuartzCore (1.7 - 270.5) <6D0EC7FC-11E5-35FB-A08A-3B438E89FBDB> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x96602000 - 0x96602ffe  libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <7F0E8EE2-9E8F-366F-9988-E2F119DB9A82> /usr/lib/system/libkeymgr.dylib
0x96603000 - 0x96611ff7  libxar-nossl.dylib (??? - ???) <5BF4DA8E-C319-354A-967E-A0C725DC8BA3> /usr/lib/libxar-nossl.dylib
0x96645000 - 0x96672ff9  com.apple.securityinterface (5.0 - 55022.6) <0FA3E84B-B5FF-3A58-A408-46280982CACC> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x96673000 - 0x96755fff  com.apple.backup.framework (1.3.5 - 1.3.5) <1FAE91F2-BCEF-387D-B5C4-412C464DA1BE> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x967a3000 - 0x96c18ff7  FaceCoreLight (1.4.7 - compatibility 1.0.0) <3E2BF587-5168-3FC5-9D8D-183A9C7C1DED> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
0x96c1b000 - 0x96c31ffe  libxpc.dylib (77.19.0 - compatibility 1.0.0) <0585AA94-F4FD-32C1-B586-22E7184B781A> /usr/lib/system/libxpc.dylib
0x96c32000 - 0x96e4eff7  com.apple.imageKit (2.1.2 - 1.0) <71FC9A62-4E07-307C-8E6B-4DE7661DC0A3> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x96e90000 - 0x96e94fff  libGIF.dylib (??? - ???) <2ADFED97-2228-343D-9A53-207CBFDE7984> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x96e95000 - 0x96ef0ff3  com.apple.Symbolication (1.3 - 91) <4D12D2EC-5010-3958-A205-9A67E972C76A> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x96ef1000 - 0x96ef8ffd  com.apple.NetFS (4.0 - 4.0) <AE731CFE-1B2E-3E46-8759-843F5FB8C24F> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x96efe000 - 0x96f76ff8  com.apple.CorePDF (3.1 - 3.1) <0074267B-F74A-30FC-8508-A14C821F0771> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x96f77000 - 0x97087fe7  libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <34E1E3CC-7B6A-3B37-8D07-1258D11E16CB> /usr/lib/libsqlite3.dylib
0x970b1000 - 0x9716eff3  ColorSyncDeprecated.dylib (4.6.0 - compatibility 1.0.0) <726898F5-E718-3F27-B415-D6FDCDE09174> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x9716f000 - 0x971d3fff  com.apple.framework.IOKit (2.0 - ???) <94827954-5906-36C4-819B-24CDAFD85C72> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x971f7000 - 0x971f7fff  com.apple.Carbon (153 - 153) <F996332A-390E-3337-A09E-A1E54004B567> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x974d3000 - 0x9753bfff  libc++.1.dylib (28.4.0 - compatibility 1.0.0) <B24814AB-CA77-3B9D-8FAB-58C9B4FD3A16> /usr/lib/libc++.1.dylib
0x9753c000 - 0x9753cfff  com.apple.quartzframework (1.5 - 1.5) <49B5CA00-083A-3D4A-9A68-4759A5CC35A6> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x975be000 - 0x975f1fef  libtidy.A.dylib (??? - ???) <E962D8EC-6B9D-35B7-B586-F07D92302ADD> /usr/lib/libtidy.A.dylib
0x98347000 - 0x98398ff9  com.apple.ScalableUserInterface (1.0 - 1) <3C39DF4D-5CAE-373A-BE08-8CD16E514337> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x98399000 - 0x983a1fff  com.apple.DiskArbitration (2.4.1 - 2.4.1) <28D5D8B5-14E8-3DA1-9085-B9BC96835ACF> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x983a2000 - 0x983f4ffb  com.apple.CoreMediaIO (216.0 - 3199.8) <A079E576-64FD-3069-846E-F3B67AF28E15> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x98408000 - 0x987fcfeb  com.apple.VideoToolbox (1.0 - 705.94) <8FCC2C08-2D4C-3A96-B57A-CAA56911120F> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x987fd000 - 0x98b43ff3  com.apple.HIToolbox (1.9 - ???) <E5EA9EEF-3CCA-36A0-8688-DA2E64E2256C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x98b44000 - 0x98b45ff7  libsystem_sandbox.dylib (??? - ???) <26960D2B-BEA6-3B3B-9BC7-D73437EF4149> /usr/lib/system/libsystem_sandbox.dylib
0x98e55000 - 0x98f18fff  com.apple.CoreServices.OSServices (478.50 - 478.50) <916A3B50-1033-3FFE-A9AF-3CC2B0F60EAE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x98f1d000 - 0x98f42ff9  libJPEG.dylib (??? - ???) <743578F6-8C0C-39CC-9F15-3A01E1616EAE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x98f43000 - 0x98f5bfff  com.apple.frameworks.preferencepanes (15.0 - 15.0) <A8CE15CF-2539-318A-910C-8789D45FFD69> /System/Library/Frameworks/PreferencePanes.framework/Versions/A/PreferencePanes
0x98f5e000 - 0x99046fff  libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <1841196F-68B5-309F-8ED1-6714B1DFEC83> /usr/lib/libxml2.2.dylib
0x990a1000 - 0x99106ff7  libvDSP.dylib (325.4.0 - compatibility 1.0.0) <4B4B32D2-4F66-3B0D-BD61-FA8429FF8507> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x99107000 - 0x99107fff  libdnsinfo.dylib (395.11.0 - compatibility 1.0.0) <7EFAD88C-AFBC-3D48-BE14-60B8EACC68D7> /usr/lib/system/libdnsinfo.dylib
0x99108000 - 0x99131fff  com.apple.shortcut (2.1 - 2.1) <60000F49-6309-34B1-88A1-588DC566C8DF> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x99132000 - 0x99140fff  libdispatch.dylib (187.10.0 - compatibility 1.0.0) <1B857064-288D-3919-B81A-38E9F4D19B54> /usr/lib/system/libdispatch.dylib
0x99141000 - 0x991a9ff3  com.apple.ISSupport (1.9.8 - 56) <59225A65-41C1-35CA-9F29-229AC427B728> /System/Library/PrivateFrameworks/ISSupport.framework/Versions/A/ISSupport
0x991aa000 - 0x991aafff  libOpenScriptingUtil.dylib (??? - ???) <E4C22B65-9493-31D5-9D46-19BD70975587> /usr/lib/libOpenScriptingUtil.dylib
0x991ab000 - 0x991beff8  com.apple.MultitouchSupport.framework (231.4 - 231.4) <083F7787-4C3B-31DA-B5BB-1993D9A9723D> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x99358000 - 0x99375fff  libresolv.9.dylib (46.1.0 - compatibility 1.0.0) <2870320A-28DA-3B44-9D82-D56E0036F6BB> /usr/lib/libresolv.9.dylib
0x99376000 - 0x993cffff  com.apple.HIServices (1.21 - ???) <91EC636D-AC27-3332-BA1C-FD7301917429> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x993d0000 - 0x994cfffb  com.apple.DiskImagesFramework (10.7.4 - 331.7) <31A74A7E-E2AE-313D-A7C4-6DFCF0F22C9A> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x994e1000 - 0x9953fff7  com.apple.coreui (1.2.2 - 165.11) <340B0B83-1407-3AB4-BCAB-505C29303EE2> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x99540000 - 0x99616aab  libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <2E272DCA-38A0-3530-BBF4-47AE678D20D4> /usr/lib/libobjc.A.dylib
0x99617000 - 0x9995dfff  com.apple.MediaToolbox (1.0 - 705.94) <89D37021-C389-3CC5-A158-620ADCBD99EF> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x9995e000 - 0x999fafff  com.apple.ink.framework (10.7.5 - 113) <05CAFB64-D3B8-3973-87EA-CB8BBE580F6B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x99a27000 - 0x99af2fff  libsystem_c.dylib (763.13.0 - compatibility 1.0.0) <52421B00-79C8-3727-94DE-62F6820B9C31> /usr/lib/system/libsystem_c.dylib
0x99af3000 - 0x99da0fff  com.apple.JavaScriptCore (7534.57 - 7534.57.3) <5AE5C3B8-D807-356B-80D9-4D0A706A10D1> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x99fa4000 - 0x99fa5ff7  libquarantine.dylib (36.7.0 - compatibility 1.0.0) <46980EC2-149D-3CF7-B29A-401FB89C275D> /usr/lib/system/libquarantine.dylib
0x99fa6000 - 0x9a03cff7  com.apple.LaunchServices (480.40 - 480.40) <D5C0DEF9-398C-3742-8C4E-875C3365EC8B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x9a03d000 - 0x9a2b1ff3  com.apple.CoreImage (7.99.1 - 1.0.1) <C4B2DD2A-8E45-31CD-9B25-2AC1CA252B14> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x9a2b2000 - 0x9a3c3ff7  libJP2.dylib (??? - ???) <3B6A6D1C-5E4D-3814-892A-7C580E063268> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x9a3cf000 - 0x9aa5bff5  com.apple.CoreAUC (6.16.12 - 6.16.12) <9D51400F-B827-3BA7-87F5-954A1CDDAEA9> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x9aa5c000 - 0x9aa74ff7  libexpat.1.dylib (7.2.0 - compatibility 7.0.0) <C7003CC0-28CA-3E04-9B9E-0A15138ED726> /usr/lib/libexpat.1.dylib
0x9aa75000 - 0x9aa7dff5  libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <BB0C7B49-600F-3551-A460-B7E36CA4C4A4> /usr/lib/system/libcopyfile.dylib
0x9aa7e000 - 0x9aa86ff3  libunwind.dylib (30.0.0 - compatibility 1.0.0) <E8DA8CEC-12D6-3C8D-B2E2-5D567C8F3CB5> /usr/lib/system/libunwind.dylib
0x9b0a3000 - 0x9b0aeffc  com.apple.NetAuth (3.1 - 3.1) <CD89526E-4FF6-3BB3-A94E-832D4504AB1C> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x9b0af000 - 0x9b0b0fff  liblangid.dylib (??? - ???) <C8C204E9-1785-3785-BBD7-22D59493B98B> /usr/lib/liblangid.dylib
0x9b149000 - 0x9b187fff  libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <AF1174F9-4402-31EB-9C84-AB644E5865DF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x9b188000 - 0x9b18bfff  com.apple.AppleSystemInfo (1.0 - 1) <0E02BA66-4EA6-3EA1-8D81-3D0DE36F1CE8> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x9b1d4000 - 0x9b1d5fff  libDiagnosticMessagesClient.dylib (??? - ???) <DB3889C2-2FC2-3087-A2A2-4C319455E35C> /usr/lib/libDiagnosticMessagesClient.dylib
0x9b1e1000 - 0x9b233ff7  libFontRegistry.dylib (??? - ???) <C2B84661-A62D-3FFF-8D8C-BC697E9BDF4C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x9b271000 - 0x9b369ff7  libFontParser.dylib (??? - ???) <71B33EB1-27F8-3C68-B940-FC61A3CFE275> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x9b36a000 - 0x9b375ffb  com.apple.speech.recognition.framework (4.0.21 - 4.0.21) <A1764D2F-EB84-33DC-9ED5-CDA3B468FF3E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x9b376000 - 0x9b376ff2  com.apple.CoreServices (53 - 53) <7CB7AA95-D5A7-366A-BB8A-035AA9E582F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x9b377000 - 0x9b3c6ffb  com.apple.AppleVAFramework (5.0.16 - 5.0.16) <1188E7AB-76FE-343F-9108-30CD67E5A37B> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x9b3c7000 - 0x9b3cbfff  com.apple.CommonPanels (1.2.5 - 94) <EA47550D-7DAF-30D9-91DB-1FB594CC8522> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x9b3d4000 - 0x9b3d9ffb  com.apple.phonenumbers (1.0 - 47) <1830301D-5409-3949-9614-C43C62B39DDA> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
0x9b406000 - 0x9b40fffc  com.apple.DisplayServicesFW (2.5.4 - 323.3) <820C4B45-814A-3101-A1FA-044CA6D2FBC8> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x9b410000 - 0x9b411ff0  libunc.dylib (24.0.0 - compatibility 1.0.0) <2F4B35B2-706C-3383-AA86-DABA409FAE45> /usr/lib/system/libunc.dylib
0x9b412000 - 0x9b413fff  libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <B04592B1-0924-3422-82FF-976B339DF567> /usr/lib/system/libsystem_blocks.dylib
0x9b654000 - 0x9b735ff7  com.apple.DiscRecording (6.0.4 - 6040.4.1) <08BADDAD-FA79-3872-9387-EEE2A9FAA2F0> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x9b73e000 - 0x9b749ff3  libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <D6E17FD4-ECA0-3EEE-BFC5-F6A42A21AB5D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x9b7a3000 - 0x9b7a4ff4  libremovefile.dylib (21.1.0 - compatibility 1.0.0) <6DE3FDC7-0BE0-3791-B6F5-C15422A8AFB8> /usr/lib/system/libremovefile.dylib
0x9b7a5000 - 0x9b7e2ff7  libcups.2.dylib (2.9.0 - compatibility 2.0.0) <007A1877-E981-3007-A8FA-9B179F4ED6D1> /usr/lib/libcups.2.dylib
0x9b7e3000 - 0x9b7e7ff7  com.apple.OpenDirectory (10.7 - 146) <4986A382-8FEF-3392-8CE9-CF6A5EE4E365> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x9b7e8000 - 0x9bcc4ff6  libBLAS.dylib (??? - ???) <134ABFC6-F29E-3DC5-8E57-E13CB6EF7B41> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x9bcc5000 - 0x9bd39fff  com.apple.CoreSymbolication (2.2 - 73.2) <FA9305CA-FB9B-3646-8C41-FF8DF15AB2C1> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x9bd3a000 - 0x9bdc7ff7  com.apple.CoreText (220.22.0 - ???) <EA7210A7-DECC-3F76-8A66-D4E41859B3C6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x9bdc8000 - 0x9be2aff3  libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <266CE9B3-526A-3C41-BA58-7AE66A3B15FD> /usr/lib/libstdc++.6.dylib
0x9be2b000 - 0x9be2cfff  com.apple.TrustEvaluationAgent (2.0 - 1) <4BB39578-2F5E-3A50-AD59-9C0AB99472EB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x9be2d000 - 0x9be30ff7  libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <69357047-7BE0-3360-A36D-000F55E39336> /usr/lib/system/libmathCommon.A.dylib
0x9be31000 - 0x9be7aff7  libGLU.dylib (??? - ???) <9AF7AD51-16E3-3674-B60E-30EE499D7B46> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x9be7b000 - 0x9be82ff9  libsystem_dnssd.dylib (??? - ???) <EBEAF723-84F8-3544-8FB2-31B7771B50D0> /usr/lib/system/libsystem_dnssd.dylib
0x9be83000 - 0x9be86ffc  libpam.2.dylib (3.0.0 - compatibility 3.0.0) <6FFDBD60-5EC6-3EFA-996B-EE030443C16C> /usr/lib/libpam.2.dylib
0x9be87000 - 0x9be87fff  com.apple.vecLib (3.7 - vecLib 3.7) <8CCF99BF-A4B7-3C01-9219-B83D2AE5F82A> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x9be88000 - 0x9bf1fff3  com.apple.securityfoundation (5.0 - 55116) <EB53CEF7-4836-39FD-B012-6BC122ED4CE9> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x9bf20000 - 0x9bf35fff  com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <92AADDB0-BADF-3B00-8941-B8390EDC931B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x9bf36000 - 0x9c006ffb  com.apple.ImageIO.framework (3.1.2 - 3.1.2) <C3CB142F-BE91-3AFA-B052-409F776C0B9E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x9c02c000 - 0x9c069fef  libGLImage.dylib (??? - ???) <FC13D46F-69C4-3BA1-A5E8-52C2EC8B7D58> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x9c06a000 - 0x9c06aff0  com.apple.ApplicationServices (41 - 41) <C48EF6B2-ABF9-35BD-A07A-A38EC0008294> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x9c10e000 - 0x9c122fff  com.apple.CFOpenDirectory (10.7 - 146) <58050170-D74E-3670-945D-D8501F67835F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x9c1ad000 - 0x9c2d9ff9  com.apple.CFNetwork (520.5.1 - 520.5.1) <F3C606BF-6DCF-33CD-981B-7253C9E3113A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x9c2da000 - 0x9c304ff1  com.apple.CoreServicesInternal (113.19 - 113.19) <F7A309D1-DCB4-38DE-8248-E16D0182AA6C> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x9c305000 - 0x9c326fff  com.apple.framework.internetaccounts (1.2 - 3) <A93D14F6-DF12-3918-90E9-B73DD7B6456D> /System/Library/PrivateFrameworks/InternetAccounts.framework/Versions/A/InternetAccounts
0x9c327000 - 0x9c327fff  com.apple.Accelerate (1.7 - Accelerate 1.7) <4192CE7A-BCE0-3D3C-AAF7-6F1B3C607386> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x9c405000 - 0x9c405fff  com.apple.audio.units.AudioUnit (1.7.3 - 1.7.3) <2E71E880-25D1-3210-8D26-21EC47ED810C> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x9c406000 - 0x9ce37fff  com.apple.WebCore (7534.57 - 7534.57.7) <5FF60D46-9BC0-3B5A-AFF1-2C965D561009> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x9ceab000 - 0x9ced5ff0  libpcre.0.dylib (1.1.0 - compatibility 1.0.0) <5CAA1478-97E0-31EA-8F50-BF09D665DD84> /usr/lib/libpcre.0.dylib
0x9cf02000 - 0x9cf31ff7  libsystem_info.dylib (??? - ???) <37640811-445B-3BB7-9934-A7C99848250D> /usr/lib/system/libsystem_info.dylib
0xbb100000 - 0xbb103fff  libLatinSuppConverter.dylib (54.0.0 - compatibility 1.0.0) <39A543C1-2604-3AB8-8148-0D76D02CE501> /System/Library/CoreServices/Encodings/libLatinSuppConverter.dylib
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 22
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 3800
    thread_create: 1
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=202.5M resident=132.3M(65%) swapped_out_or_unallocated=70.2M(35%)
Writable regions: Total=256.6M written=67.4M(26%) resident=174.0M(68%) swapped_out=0K(0%) unallocated=82.6M(32%)
REGION TYPE                      VIRTUAL
ATS (font support)                 32.9M
CG backing stores                  81.4M
CG image                             16K
CG raster data                     1188K
CG shared images                   3480K
CoreGraphics                          8K
CoreImage                             4K
CoreServices                       3092K
MALLOC                            112.6M
MALLOC guard page                    64K
Memory tag=240                        4K
Memory tag=242                       12K
Memory tag=243                        4K
Memory tag=249                      156K
OpenCL                                8K
Stack                              66.1M
VM_ALLOCATE                        16.6M
__CI_BITMAP                          80K
__DATA                             11.7M
__DATA/__OBJC                       332K
__IMAGE                             528K
__IMPORT                             32K
__LINKEDIT                         47.2M
__OBJC                             3432K
__OBJC/__DATA                        52K
__PAGEZERO                            4K
__TEXT                            155.3M
__UNICODE                           544K
mapped file                       116.5M
shared memory                      3832K
shared pmap                        6040K
TOTAL                             662.6M
Model: MacBook5,1, BootROM MB51.007D.B03, 2 processors, Intel Core 2 Duo, 2.4 GHz, 3 GB, SMC 1.40f2
Graphics: NVIDIA GeForce 9400M, NVIDIA GeForce 9400M, PCI, 256 MB
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1067 MHz, 0x859B, 0x435432353636344243313036372E4D38464D
Memory Module: BANK 0/DIMM1, 1 GB, DDR3, 1067 MHz, 0x802C, 0x384A53463132383634485A2D314731463120
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.106.198.19.22)
Bluetooth: Version 4.0.8f17, 2 service, 11 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: TOSHIBA MK2555GSXF, 250.06 GB
Serial ATA Device: MATSHITADVD-R   UJ-868
USB Device: G-DRIVE slim, 0x4971, 0x8005, 0x24100000 / 2
USB Device: Built-in iSight, apple_vendor_id, 0x8507, 0x24400000 / 3
USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0236, 0x04600000 / 3
USB Device: IR Receiver, apple_vendor_id, 0x8242, 0x04500000 / 2
USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x06100000 / 2
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8213, 0x06110000 / 3
The .AUP file is the Audacity Project Manager. It’s a relatively short text file and it tells Audacity what to do with all the stuff inside the _DATA folder. The _DATA folder holds the show in snippets and fragments. The AUP file and the _DATA folder must be in the same place or folder for the show to open. They must see each other.
This is a graphically spiffed up AUP file for illustration. You can read it. It tells you names and locations and other information as well as telling Audacity how to construct the show. AUP files get very much more complex after editing and production.
http://kozco.com/tech/audacity/aup1.jpg
I Save to the desktop and I always Export to WAV (on the desktop) at the end of every performance. I think under certain conditions, Audacity will try to save your show to the /Applications folder. That would be bad. Move to the Desktop.
I’m not sure why I was having all the issue when all the files were somewhere on the macbook, but somehow I got it. I prefer working on my big imac, so I save the file to a flash drive, put it in the imac and imported the info. worked eventually. so what would be the best method for transferring the session to the imac so I can edit it there?
BTW koz, todays session+ was the best yet. I moved the stands behind the furniture, so the dog/peoples feet wouldn’t hit it. seemed to get good sound and waves.
There is a lot about the Mac that doesn’t care, but it’s still really bad form to put show data in /Applications and applications on the /Desktop for just two examples. You can cause serious Mac problems by doing that trick to the wrong folder.
You did it. Save the Project to your desktop, mount the Flash Drive and drag the AUP file and _DATA folder with the same name over to it. This should work famously if you do no editing or production on the original Mac. I would still Export a Microsoft WAV file and carry that over, too. Don’t join the list of people posting “I tried to open my once-in-a-lifetime Project and Audacity keeps crashing. Please help!”
No problem, just open the WAV file and use that. There are very minor differences between the two methods, but in the face of disaster, they’re the same.
Never record an important guest as the first time you ever shot sound. It gets better as you go. Sometimes much better.
Are you starting to look a little like that?
I was surprised at one of the meetings when I was introduced to a woman “fish pole” operator.
http://kozco.com/tech/audacity/pix/Boom.jpg
I asked her if she had any trouble with the upper body strength needed to do that. “No, not really,” and she picked me up and carefully put me down out of the way.
NO wav…ok will use the wav backup system. thanks.
yes, that is how I’m feeling. the interviews seem to think I actually know what I’m doing. :laughing:
And after four or five of those and recovering from some silly mistakes, you will.
Left out a step. You have to post some of the work. Since this is not Error Diagnostics any more, you can use mono, high quality MP3 (128 quality or better) and get quite a number of seconds posted on the forum. If you want to post a more serous, longer sample at even higher quality, I can host it on kozco.com. Let me know. Koz
