Lost it all
Hello, I was working on a recording when my computer completely crashed. It came back up again and of course Audacity gave me a restore file. However, when I opened this restore file, most of the audio was missing, only a few clips played. So I decided to just go back to my last save file, so I closed the program out without saving.
But then, when I opened the original save file, nothing came up! All of the audio is completely gone. This makes no sense because I have all of the data still right there, none of it is gone. And I can still see the edit points in the audacity interface. There should have been nothing wrong with this save file.
A quick response would be much appreciated.
I am using Mac OS 10.14, Mojave, and Audacity 2.3.0.
Hello… can anyone help?
I’m really scared…
I had this same problem as well
Which was an Audacity Project, right? Did you change the project name between the two shows? We’re trying to nail down why working on a Project and creating damage should also damage an older project.
One of the Audacity versions had a serious problem where SAVE and SAVE-AS wouldn’t cross in a predictable manner. If you’re using Audacity 2.3.1, you don’t have that problem.
Somewhere in there, you should have Exported a WAV (Microsoft) 16-bit sound file rather than project after project.
Audacity doesn’t save files. It Exports sound files such as WAV and MP3 and it Saves Projects which are a collection of files and folders.
This is a Project.
You know you’re in trouble when somebody opens a post with “…I saved an Audacity File.”
