When I was being taught computing in the '90s, it was hammered into us that the first lines in ANY code should collect the user’s current environment, and that the last few lines MUST re-instate those conditions.
As beautiful as Audacity might be, its persistent ignoring of the above rule has, from time to time, made some Effects almost unusable. I don’t, for example, expect to have to use the mouse after using my keyboard shortcut to restore Zoom to Normal.
Lack of discipline.
Poor show.
Buck up!
I am unable to reproduce your issue. What version of Audacity are you referring to? What OS ?
When I was being taught computing, it was hammered into us that, if something does not work the way that you expect it to, rtfm.
