Lose Sound with Audacity 2.2
Having problems,
When I start to play a album with the Audacity Software on the music plays for about 20 sec than stops, I am running windows 10 on a Alienware laptop. I checked the Audacity Logs and see this:
20:42:34: Trying to load FFmpeg libraries from default path, ‘C:\Program Files (x86)\FFmpeg for Audacity\avformat-55.dll’.
20:42:34: Looking up PATH environment variable…
20:42:34: PATH = 'C:\Program Files (x86)\Intel\iCLS Client;C:\Program Files\Intel\iCLS Client;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files (x86)\Windows Live\Shared;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0'
20:42:34: Checking that ‘C:\Program Files (x86)\FFmpeg for Audacity’ is in PATH…
20:42:34: Warning: FFmpeg directory ‘C:\Program Files (x86)\FFmpeg for Audacity’ is not in PATH.
20:42:34: Temporarily prepending ‘;C:\Program Files (x86)\FFmpeg for Audacity’ to PATH…
20:42:34: Checking for monolithic avformat from ‘C:\Program Files (x86)\FFmpeg for Audacity\avformat-55.dll’.
20:42:34: Error: Couldn’t find symbol ‘avutil_version’ in a dynamic library (error 127: the specified procedure could not be found.)
20:42:34: Error: Couldn’t find symbol ‘avcodec_version’ in a dynamic library (error 127: the specified procedure could not be found.)
20:42:34: avformat not monolithic
20:42:34: Loading avutil from ‘avutil-52.dll’.
20:42:34: Loading avcodec from ‘avcodec-55.dll’.
20:42:34: Loading avformat from ‘C:\Program Files (x86)\FFmpeg for Audacity\avformat-55.dll’.
20:42:34: Returning PATH to previous setting…
20:42:34: Actual avutil path C:\Program Files (x86)\FFmpeg for Audacity\avutil-52.dll
20:42:34: Actual avcodec path C:\Program Files (x86)\FFmpeg for Audacity\avcodec-55.dll
20:42:34: Actual avformat path C:\Program Files (x86)\FFmpeg for Audacity\avformat-55.dll
20:42:34: Importing symbols…
20:42:34: All symbols loaded successfully. Initializing the library.
20:42:34: Retrieving FFmpeg library version numbers:
20:42:34: AVCodec version 0x373466 - 55.52.102 (built against 0x373466 - 55.52.102)
20:42:34: AVFormat version 0x372164 - 55.33.100 (built against 0x372164 - 55.33.100)
20:42:34: AVUtil version 0x344264 - 52.66.100 (built against 0x344264 - 52.66.100)
20:42:34: FFmpeg libraries loaded successfully
I need Help Please !!!
There is no Audacity 2.2 supplied by us.
If that is not a typo, I suggest you uninstall that version, run an anti-virus check on your computer, then install the current Audacity 2.1.2 release from our site: http://www.audacityteam.org/download/windows.
FFmpeg is an optional library that lets Audacity import and export more audio formats. It does not seem that is relevant to your problem, especially given Audacity loads it properly according to the log.
What audio are you trying to play, and on what sound device? You can show us your audio devices by posting Help > Audio Device Info… top right of Audacity.
If it’s a recording you made with a microphone, you may need to turn off Windows corrective audio enhancements.
If you upgraded to Windows 10 over previous Windows on the same machine, you should go to the Alienware site to install the latest Windows 10 audio drivers intended for your specific computer model.
If you are playing to an external sound card or PCI sound card (some sound card other than the one built-in to the motherboard) you need to go to that manufacturer’s site to look for Windows 10 drivers.
If you don’t have compatible or correct audio drivers for your sound device(s), then bad playback or recording may result.
