Long Time to exporting ac3
hi guys,
my problem is a long time for exporting audio ac3, why ???
USE 2.4.1
before the update in 5/8 minutes and now 20/25… :unamused:
I assume that you are referring to a previous version of Audacity? Which version? Are you comparing both on the same computer with the same Audacity project?
I don’t remember the other version…I upgrade every time…
(ps my ac3 usually is 6ch)
Hmmm I see what you mean
I created a stero 30 minut chirp for AC3 Export
  1. 2.3.3 export takes 19 seconds
  2. 2.4.1 export takes 96 seconnds
The good new is that when I test this on the latest 2.4.2 alpha test build the export time goes back down to 19 seconds again
I suspect this is another symptom of a P1 bug we fixed for 2.4.2 where WAV exports had similarly slowed down.
https://bugzilla.audacityteam.org/show_bug.cgi?id=2457
Windows: WAV Export runs 6 to 7 times slower than on 2.3.3
But thanks for the bug report - much appreciated :sunglasses:
Peter
I added an entry to the (closed) bug thread for this:
https://bugzilla.audacityteam.org/show_bug.cgi?id=2457#c10
Peter.
:smiley: ok thx
I’m whaiting new update
<3<3<3
Current forecast/scheduled date is end of this month.
Peter
