Loading rmsnormalize.ny
Hi
Am trying to load the rmsnormalize.ny plugin on OSX. Have put file in plugin folder of audacity try to enable in effects but it is not visible to enable. Tried all I know and wonder if anyone can help.
Mac 10 11 6
Audacity 2 2 0
Thanks
Make sure the download didn’t add “.txt” to the end of the filename. You can get MacOS to hide filenames now (which I think is a terrible idea) and you won’t see it.
Right-click or Control-Tap the file > Get INFO. That should give you the real filename.
Also, there are two places to put the file.
Go (top of the desktop) > Go To Folder >
Plugins.
Don’t leave out the squiggly line at the front.
Please note you can get into trouble by using RMS Normalize by itself. It was designed to be used as part of an Audiobook Mastering suite of tools.
https://wiki.audacityteam.org/wiki/AudioBook_Mastering
