Hi !
Is there a way to automatically modify the recorded input and send it again in another emulated mic ?
I did a quick schema :
http://i.imgur.com/FdZ5hwh.png
And everything of this automatically and in real time. Is it possible with Audacity ?
Hi !
No, Audacity does not do real-time processing other than “real-time preview” in some effects.
What kind of sound modification? What’s you situation/application? Do you have a PA system or something?
Most DAW (digital audio workstation) software such as REAPER, Cubase, SONAR, etc., can do real-time effects.
Or, you can search for a [u]VST Host[/u], which can host a variety of VST effect plug-ins. ([u]VST[/u] is the most popular effect plug-in protocol and you can find lots of free or commercial VST effects.)
But, there is always some latency (delay) through the computer* and some effect plug-ins add more delay. And, it can sometimes be a pain getting the delay down to an acceptable level.
The best solution for “live” real-time use is a hardware effects box ([u]example[/u]).
Note that most of these effect boxes are line-level. That is, they are connected after the mic preamp (or they are plugged into an effect-loop on a mixer, etc.).
The same would be true for a computer solution… Computer’s and USB audio interfaces don’t have microphone-level outputs. There are a few with microphone inputs and mic-level outputs, and of course there are tons of effects/pedals designed for guitars. Oh… Anything with a mic input is going to be designed for a stage/studio mic (balanced low impedance with an XLR connector) and it won’t work with a computer mic.
Ok, thanks for your answer, it looks like that I want to do isn’t possible for Audacity.
But I think of another software, and : is it possible to record the sound of the computer, with a plugin or something ?
To record the sound of the computer (Windows Vista or later), use “WASAPI loopback”. See: http://manual.audacityteam.org/o/man/tutorial_recording_computer_playback_on_windows.html
Thanks !
I have no more questions, if a moderator can lock it…
