When I download two songs and split each track to mono. I then try to listen to each track but both tracks plays. Even after selecting one track (yellow boarder around the track). Is there something I’m not doing in the play mode? Thanks
To listen to just one track, click the track’s “Solo” button.
(Note that when you Export, any tracks that are muted are not included in the mix.)
Thanks Steve. But, when I download two songs and split each track to mono. I then try to listen to each track but both tracks plays at the same time. Even after selecting one track (yellow boarder around the track). If I select one track and select play both tracks plays together. why is that? selecting solo works to listen. When I select one track shouldn’t that track only play. It looks like both tracks are some how linked together. Also noticed that when I edit/cut one track both tracks cut at the same place. Is there something I’m not doing? How do you make each track independent. Thanks
