I’m not sure what’s going on tried more then once to install and run Audacity This is what I’m getting
audacity: error while loading shared libraries: libid3tag.so.0: wrong ELF class: ELFCLASS32
I’ve tried everything including purge and re-install
Please note that Audacity Team does not supply Audacity packages for Linux distributions.
Is this your question http://forums.linuxmint.com/viewtopic.php?f=47&t=170050&p=874034 ? If not, others have the same problem.
The error indicates that 64-bit libraries are expected. Audacity builds as I understand it should be 64-bit on a 64-bit Linux system. Do you have a 64-bit computer, and did you install a 64-bit version of Linux Mint?
If you think this a Linux Mint bug and get no answer on their forums you should report it here: https://bugs.launchpad.net/linuxmint .
You could also try compiling Audacity yourself with the libid3tag libraries that ship with Audacity:
./configure --with-libid3tag=local
It should be fairly simple to compile Audacity on Linux Mint. See: http://wiki.audacityteam.org/wiki/CompilingAudacityForBeginners#simple .
