Hello
I wanted to record something from my smartphone via Line in. I had everything set up and testet it for 30 secs before I attempted to record the whole 7 hours. In the middle of the night ther was a crash. didnt know what happened. I had enough place on my hard disk an my pc is not bad (I7, 16gb ram …)
The log-data is in german. can anyone help ?
thank you
05:02:02: Audacity 2.0.5
05:02:02: Trying to load FFmpeg libraries...
05:02:02: Trying to load FFmpeg libraries from system paths. File name is 'avformat-52.dll'.
05:02:02: Looking up PATH environment variable...
05:02:02: PATH = 'C:Program Files (x86)NVIDIA CorporationPhysXCommon;C:Program Files (x86)InteliCLS Client;C:Program FilesInteliCLS Client;C:Windowssystem32;C:Windows;C:WindowsSystem32Wbem;C:WindowsSystem32WindowsPowerShellv1.0;C:Program FilesIntelIntel(R) Management Engine ComponentsDAL;C:Program FilesIntelIntel(R) Management Engine ComponentsIPT;C:Program Files (x86)IntelIntel(R) Management Engine ComponentsDAL;C:Program Files (x86)IntelIntel(R) Management Engine ComponentsIPT'
05:02:02: Checking that '' is in PATH...
05:02:02: FFmpeg directory is in PATH.
05:02:02: Checking for monolithic avformat from 'avformat-52.dll'.
05:02:02: Fehler: Laden der DLL 'avformat-52.dll' gescheitert (Fehler 126: das angegebene Modul wurde nicht gefunden.)
05:02:02: Loading avutil from 'avutil-50.dll'.
05:02:02: Fehler: Laden der DLL 'avutil-50.dll' gescheitert (Fehler 126: das angegebene Modul wurde nicht gefunden.)
05:02:02: Loading avcodec from 'avcodec-52.dll'.
05:02:02: Fehler: Laden der DLL 'avcodec-52.dll' gescheitert (Fehler 126: das angegebene Modul wurde nicht gefunden.)
05:02:02: Loading avformat from 'avformat-52.dll'.
05:02:02: Fehler: Failed to load FFmpeg libraries.
05:02:02: Fehler: Es konnten keine passenden FFmpeg-Bibliotheken gefunden werden.
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000013.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000024.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e000003d.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000061.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e00000e6.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e00000e9.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000176.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e000017b.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e00001e7.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000247.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e000025b.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e00002a7.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e00002a8.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e00002c9.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000317.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000323.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e000035a.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e00003c3.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000442.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e000046a.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e00004c1.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e00004d4.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e00004dd.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e000059a.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e00005a2.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e00005d4.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000603.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e000060b.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000647.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e00006f7.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000711.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000721.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000736.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000764.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e00007ad.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000837.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000851.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000881.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e00008a1.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000912.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000923.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e000095c.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e00009a0.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e00009b6.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e00009b9.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e00009c8.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000a80.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000a9b.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000ad5.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000af9.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000b5e.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000ba0.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000bf2.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000c79.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000c88.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000cae.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000cd7.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000cf0.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000d0e.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000d2a.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000d71.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000d7f.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000dbe.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000dcb.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000e03.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000e55.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000eb3.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000ecf.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000f4b.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000fd0.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000ff2.au'
05:02:25: Warnung: Nicht zuzuordnende Block-Datei: 'C:UsersMichaelAppDataLocalTempaudacity_tempproject14086e00d00e0000ffe.au'
05:02:25: Warnung: Die Projekt-Überprüfung ignorierte die nicht zuzuordnenden Blockdateien. Sie werden beim Speichern gelöscht.
05:02:25: Warnung: Die Projekt-Überprüfung fand Unstimmigkeiten bei den Projektdaten.
