libogg failing on OSX 10.6.8
libogg failing compilation on OSX 10.6.8
=== configuring in lib-src/libogg (/Users/noah/audacity-src-2.0.1/lib-src/libogg)
configure: running /bin/sh ./configure ‘–prefix=/usr/local/’ ‘–with-wx-config=/usr/bin/wx-config’ ‘–disable-programs’ ‘–disable-programs’ ‘–disable-programs’ ‘–with-pa-include=…/portaudio-v19/include’ --cache-file=/dev/null --srcdir=.
configure: WARNING: unrecognized options: --with-wx-config, --disable-programs, --disable-programs, --disable-programs, --with-pa-include
./configure: line 2050: syntax error near unexpected token libogg,1.1.3' ./configure: line 2050: AM_INIT_AUTOMAKE(libogg,1.1.3)’
configure: error: ./configure failed for lib-src/
  • libogg
any clues how to fix this?
What is your actual configure command? What libogg are you asking Audacity to use?
just running ‘./configure’ without libogg switches. this is the audacity fullversion source code file.
