latency in headphones during recording Apollo Twin - Macbook Air M1
The super short version: Plug your wired headphones into the Twin. Make sure Audacity > Preferences > Recording > Playthrough is off.
The advertising for this thing is too fancy by half. It suggests, buried in the fancy-pants graphics, that there is a headphone connection on the front of the Twin. Use that one. If you’re plugged into the computer or you have wireless headphones, you’re pretty much doomed to always get echo or recording latency.
