A l’aide: Il y a beaucoup de décalage entre l’enregistrement de ma guitare à travers un microphone et la bande son qui est installée dans mon ordinateur. J’ai utilisé la double flèche de glissement temporel mais comme le décalage est important, il y a de nombreux glissements et lorsqu’enfin le calage semble OK je n’arrive plus à lire le morceau en entier. Pouvez vous m’aider?
Using: There are many difference between recording my guitar through a microphone and the sound that is installed in my computer. I used the double arrow slip but as the time lag, there are many landslides and when at the timing seems OK I can no longer read the entire piece. Can you help me?
Have you read the Recording FAQ’s:
http://manual.audacityteam.org/man/FAQ:Recording/fr
If you are getting dropouts and that is the reason for the lack of synchronisation, read these tips (it is a machine translation only):
http://tinyurl.com/dx8d4j4
