[Win10.0.18363 , Audacity 3.2.0]
I use the Finnish Windows operating system, but I want to use the English user interface in Audacity.
The problem is following: even if I choose from the language menu
(Preferences - Interface → Language Language selection combobox)
any language, so many menu texts are still in Finnish.
For example, in the menus ‘Effect → Paul Licameli’ and ‘Effect → Steve Daulton’, all menu titles are in Finnish, even if English or any other language is selected as the user interface language.
Is this possibly a problem with the language pack, or does that operating system language penetrate some menus from the Windows system level, in which case it would be a programming error, which I believe could be easily fixed?
I have noticed the same problem already in the previous version of Audacity.
This issue has been reported to the developers and you may follow it here: https://github.com/audacity/audacity/issues/3794
Does this issue still occur in 3.2.1 ?
Yes. I tested Audacity 3.2.1 and this problem remains.
Here’s a list of menu titles that still remain in Finnish, even if any other language is selected as Audacity’s interface language
(menu texts in English here).
Generate
- Pluck
- Risset Drum
- Rhythm track
Effect
- Clip fix
- Vocoder
- Vocal Reduction and Isolation
- Notch Filter
Tools
- Nyquist Plugin Installer
- Sample Data Import
- Sample Data Export
- Regular Interval Labels
And as I said before, in the menus ‘Effect → Paul Licameli’ and ‘Effect → Steve Daulton’, all menu titles are in Finnish, even if English or any other language is selected as the user interface language in Audacity.
Analyze
- Label Sounds
- Beat Finder
