Lame_v3.99.3_for_Windows.exe not downloading, now what?
I cannot get the download for Lame_v3.99.3_for_Windows.exe
http://lame1.buanzo.com.ar/#lamewindl
The download simply doesn’t start. I’ve cleared cache/cookies, rebooted, nothing.
Is there a mirror site or another way to download it? Anyone know?
I’ve just checked it - it’s working now.
Actually, I just installed the alternative 3.98.4 build. That was at sourceforge, so it worked fine.
It does what I need it to do, so far.
Only if buanzo’s site is down, you can use this link instead (fixed URL for whatever the latest recommended lame version for Audacity is):
http://gaclrecords.org.uk/software/lame_enc.dll .
The recommended version is 3.99.3 now.
I am a little surprised you found a lame_enc.dll version from Sourceforge that Audacity accepted. Generally speaking, Audacity only accepts the versions from buanzo’s site or the above UK site.
