Hi. I haven’t even started recording in Audacity yet, because I have it set to hear myself when recording, and the lag (echo) of my voice and even the clicks of my keyboard/trackpad are impossible. I searched for possible fixes, and set the buffer to zero, as well as latency, and still no joy. I wanted to try Audacity because I heard it was good for editing sibilance and other noise in spoken word recordings, and also it has good output options, but this difference from Garageband may be a dealbreaker. Any ideas?
I am using 4.0.126 something (can’t copy the version, weird) on a MBPro M4 running Sequoia 15.7.3 (can’t update to the latest OS because it will brick some software I can’t replace).
Audacity has never had zero-latency input monitoring. The latency setting refers to an adjustment made after recording overdubs to compensate for recording latency (a different thing).
If Garageband works for you, then you could use it for recording then export the recordings as AIFs and import them into an Audacity project.
What microphone and/or interface are you using? It might have input monitoring built in.
Oh, and stick with version 3.7.9 for now. Audacity 4 is still missing a lot of features and has quite a few bugs.
You can get Audacity 3.7.9 here: Download Older Versions of Audacity
Thanks for the older version link, I was wondering about that, especially given my OS isn’t up to date. I’m using a Focusrite Scarlett 2i2 3rd generation with an XLR cardioid mic. You’re right, I reckon I can use that monitoring, but I’m just used to doing it the other way, and habits are hard to break
