Label Sounds
First post. Please bear with me.
Using presets in Label Sounds could be improved by:
  1. Displaying the preset name in the Label Sounds box
  2. Defaulting to the last used preset (and maybe it is but there’s no way of knowing unless you remember what settings are associated with the presets
  3. When changing an existing preset, you have to know the name of the preset you wish to overwrite. Having the preset displayed in the dialog box would keep you from having to remember the names & settings
  4. When deleting a preset, that preset should be displayed so you can easily see what you’re deleting instead of just going by the name.
Thank you.
