Label Sounds not working
earlier, with the same settings, it found a voice, not silence. Now I don’t understand what the problem is
For reference*
I find a voice using audacity, then I use my script Edit decision list - Wikipedia
I want to change it so that at high dB it finds a voice, but now it only finds at low dB
I am currently using 3.1.1 version, previously downloaded from 3.0.0 to the newest - the problem remains
(translate for google)
When dealing with “signal level” (the level of the audio in a track), the more negative the number of dB, the quieter (lower level) it is. -37.9 dB is 17 dB lower than -20.9.
Looking at your first screenshot, it looks like the “noise” level immediately after the highlighted section is probably higher than -37.9 dB, and will therefore not be recognised as “silence” but as a continuation of the sound.
Is it possible to make it so that the voice can be found at high -xx dB?
Yes, set a higher “Threshold” level.
Note that “Average” level and “RMS” level are lower than “Peak” level (I don’t know which you are using as I can’t read that language).
Oh, thank you.
