Label Sounds not working - version 3.7.1
I noticed that there are some posts from 2021 addressing this issue, but it seems like those problems would have been fixed by now. Back then, it was said that the Nyquist plugins had a problem with longer files.
Now, the file that I am using is VERY long (25 hours), so is that still a problem with this plugin?? If I select smaller sections of the file to analyze, I get the results that I would expect.
Thank you for your help!
–Jim
