Hello! I’m editing a track and after running the high pass and low pass filters, normalizing the sound, and using the limiter, ACX Check says the noise floor is too low. So I undid the limiter, normalization and filters to start over and ran the Label Sounds plug-in, but its not finding any silences. I used the Label Sounds default settings. Not sure what I may be doing wrong? Grateful for any help!
Which version of Audacity are you using?
Try these settings, and let us know what happens:
I’m using version 3.0.3. That worked!!! Thanks so much!
