j’ai un macbook pro 15’ I7 de 2010 avec mac OS 10.6.6.
Je ne parviens pas à faire fonctionner la derniere version d’audacity dessus:
Je précise que j’ai bien respecté la procédure d’installation mais au lancement, il plante systématiquement après un temps d’attente (ou je vois le raccourcis du doc bouger).
Etonnament la version 1.2.5 elle marche.
Y a-t-il une astuce pour pouvoir travailler avec la derniere version d’audacity?
Je ne peux pas parler français, mais le problème se pose avec les effets AudioUnits ou VST.
Renommez le fichier attaché “audacity.txt” en “audacity.cfg” et collez-le dans ~/Library/Application Support/audacity (~/Bibliothèque/Application Support/audacity) ?
You have to rename the attached “audacity.txt” to “audacity.cfg” (we cannot attach files with .cfg extension).
Then open Finder and go to ~/Library/Application Support/audacity. “~” means your Home directory. “Library” and “Application Support” may be translated if you are running Mac in French.
Then paste “audacity.cfg” in ~/Library/Application Support/audacity . There will not be any “audacity.cfg” there if Audacity has never been closed normally. That does not matter - just paste in the new “audacity.cfg” and then launch Audacity.
The new “audacity.cfg” disables Audio Unit and VST effects so this assumes you do not want to run those effects in Audacity. If you want to run VST effects in Audacity you have to find the locations they are loading from so you can find out which plug-in(s) are causing the problem: http://wiki.audacityteam.org/wiki/VST_Plug-ins#locations
Are you sure you put audacity.cfg in ~/Library/Application Support/audacity (or whatever ~/Library/Application Support/ is called in French)? Was Audacity force quit before you added audacity.cfg and launched Audacity?
If there is still a problem, what exactly happens if you wait one minute after launching Audacity? Can you attach a screenshot (picture) of what you see?
