Simple question. I am recording vocals through one mic. The mic records in stereo audio. And, obviously, the audio sounds quite dry. I am just looking for a way to make the vocals sound more full and surrounding without adding more microphones. Is this possible in audacity? Thanks!
Post a voice segment. Do you have it together enough to make an MP3? that takes special Lame additional software in Audacity. Assuming you’re using Audacity 2.1.2.
http://manual.audacityteam.org/help/manual/man/faq_installation_and_plug_ins.html#maclame
Select a representative vocal segment and Export MP3 with at least 256 Quality. I would normally go on about a ten second, perfect quality, WAV export, etc, but we’re not analyzing waveforms or technology this time. Just voice. You can’t go over about a 2MB file, which works out to about a minute stereo at 256 quality.
Scroll down from one of these forum text windows > Upload Attachment > Browse.
Do you already perform live for appreciative audiences and want to record the work?
“Chorus” plugin ? , see … https://forum.audacityteam.org/t/chorus-effect/26335/1
or “Pseudo-Stereo” … http://wiki.audacityteam.org/wiki/Nyquist_Effect_Plug-ins#Pseudo-Stereo
I’ll have to give that plugin a try.
