just started using please help
i got a numark mixtrrack pro for christmas and after awhile i wanted to record i got a behringer uca222 and plugged it into the second output of my mixtrack when i recorded in audacity it did not record my cross fades/cuts instead it just played the tracks simutanisly can someone tell me how to fix it :question:
Read the instructions. The two stereo outputs of the MixTrack are not the same. Only one of them is the mixed show. The other is a pre-mix or effects-out or something like that. We had another poster with the same problem.
You can use an RCA to RCA cable and your earbuds or headphones to tell what’s happening. Plug the RCA cable into each output and listen to it with your earbuds.
http://www.kozco.com/tech/audacity/pix/earBudsRCA.jpg
