In some cases I have recorded records as two separate files, Side1.mp3 and Side2.mp3.
Now I would like to join them into one file. How do I do that with Audacity?
- Import the two files into Audacity.
- “Ctrl + A” (select All)
- Tracks menu > Align tracks end to end (the exact menu item depends on which version of Audacity)
- Export.
Thanks, but end to end caused them to be mixed side by side.
What is the correct option please?
PS: I found this: https://www.youtube.com/watch?v=d-nxFHYsxN0
but I can’t seem to drag the second file. How do I drag it?
That video has nothing to do with Audacity. Did you post the wrong link?
To drag an audio clip, use the Time Shift tool.
OK, sorry. I just worked it out. I didn’t at first use Select All. When I do,
end to end does shift the second one to start at the end of the first.
So all is well. Thanks.
