I've built a tool to split speakers in the recording
Often, users on Reddit aks for a tool to separate speakers during podcasts and export them in separate files. Usually, people have from a recording or a zoom-call a mixed audio file, which they need to edit manually – it is tremendous waste of time.
I’ve developed a VST3 plug-in for any DAW (Digital Audio Workstation) application like Audacity, Adobe Audition, REAPER to identify and split speakers into separate audio tracks (max 10). This tool runs locally on computer and ideal for podcasts, interviews, post-production, and research. It uses a lightweight ONNX machine learning model to detect speaker boundaries and export per-voice files, saving you hours of manual editing.
I’ll answer your all questions related to the product or its development.
Here’s the link.
What does it do when two people are speaking at the same time ?, Can is separate overlapping speakers ?.
It can’t. In this case, the editor must manually edit that section. It also helps to provide three speakers as input, so the machine learning model can identify the synchrony of two speakers as a “third” one.
