is this right?
hi
if i open up my documents thoght start…my documents…all the recorded tunes (with the headphones)are listed just after
the data versions of these tunes…if i look at my documents though audicity the headphone tunes that were listed just under
the data tunes like in the other my documents are gone…why?where can o look 4 them?
coonsanders
Curious…
On my machine, if I use the horizontal scrollbar on Audacity’s “Open” window, all the “headphone” files magically appear…
On the Audacity “Open” browser, you can select what kind of files you want to see. The default is “All supported files”.
