I wanna make some edits to songs where for example all notes are a single note or it’s in G minor or whatever. Is there some type of plugin or audacity setting that can do that? I’m on Audacity version 2.3.0
Yes, you CAN change the key with the [u]Change Pitch Effect[/u] but it changes ALL of the notes/music by a certain number of notes/semitones (or by a percentage) so it’s helpful if you know the existing key if you want to end-up on G-minor. And, it will still sound like music.
I don’t know how to use it, I can turn everything off and it sounds the same, I can turn everything on and it sounds the same, I can set everything at like 50000 different configurations and it all sounds the same except for tiny changes like it goes 0.01% louder or there’s half a wave of static noise in the middle somewhere. I’m better off manually drawing the frequency waves than using this tool
Yes, there are certainly a lot of possible configurations! I had toyed with this tool a little while ago and was moderately successful at “auto-tuning” up some flat notes on a sample track with only one voice. For your requirements, I suggest looking for internet videos on how to use gsnap, or other possible plug-ins.
