In Audacity 3, when the cursor was in a clip, Home and End keys would move to the start and end of the clip respectively. In Audacity 4, by default, they do nothing. I found a post that suggested I set the Rewind to start and Rewind to end action keys in Preferences.
That worked great until I used the upper clip handles to remove the first minute of the clip. The Home key goes to the 0 position rather than the current start of the clip. That is not helpful. I need a key to get me to the active start of a clip, not where the clip originally started. The End key, mapped to Rewind to end, does work how I need it to, going to the active end of the clip, not the original end, which I’d truncated.
