Is there a possibility to have multiple segments conspiquously selected?
Dear Team Leaders and Senior Members,
Let us assume that I wish to utilise the tool “Effect/Truncate Silence…” to remove specific areas of silences below a pre-determined Threshold.
Before the effect is applied, is it possible to observe those specific distinct segments that would be removed as a result of applying the effect of “Truncate Silence”, that could be scrolled all along the file visually in read-only mode, so that one accidental click doesn’t have those segments dis-selected?
A very essential tool, if it is there already.
Majorly solved by Mr. Daulton’s label-sounds.ny tool. Solution is found from a later post.
