Hi Folks,
Simple question - is there a keyboard command that allows me to scroll the waveform view sideways?
Cheers,
Chris
Hi Folks,
Cheers,
Chris
At present you have to use the SHIFT modifier when moving the finger/ball/wheel. This might be fixable if we are able to move Mac to wx3.0.2. See Mouse Preferences - Audacity Manual.
Thanks!
I just checked and on my MacBook I can scroll by SHIFT + Two-Finger-Swipe - that’s fine!
Cheers,
Chris
