Is it possible to record from the line in of a CR6249A?
This software (Audacity 2.0.5) came with the Crosley USB turntable CR6249A that I purchased. I would like to know if it’s possible to record from the line in on the turntable as the source instead of a record.
I couldn’t find the actual specs or user manual, but I don’t think it has line-in, I think it only has line-out.
If it has line-in, there would be at least two pair of RCA connectors (stereo-in and stereo-out) plus a switch labeled “Phono - Aux”, or “Phono - Tape” for switching between the phono and another source.
If you have a laptop with no line-in, the Behringer UCA202 is usually the least expensive solution. (Beware - Most regular “USB Soundcards” have only mic-in and headphone-out. If you want to look for other devices similar to the UCA202, do a search for “USB Audio Interface”).
I couldn’t, either.
