inverted selection
Hi while using the keyboard and working in audacity I changed something. The highlight is now on the outside of the wave part instead of on the wave part itself. I tried looking for a solution but not sure how I would word this and haven’t found anything searching…
Can anyone help?
Post a screen capture of what you have now. Try to select something and post the error.
https://forum.audacityteam.org/t/how-to-attach-files-to-forum-posts/24026/1
Try pressing F1 on your keyboard to go back to Selection Tool. I think you may have turned on Multi-Tool (F6) or Envelope Tool (F2) .
