Interviews - silencing tracks when one person is talking
Newbie altert!]
Hi Guys - searched for ages and havent found this one.
New to podcasting. Recorded a ~30min interview using two lavilier microphones.
When one person is talking I am going through the tracks silencing the other microphone to remove breathing noise, crackles, and the weaker signal of the other person talking.
This is taking a loooooong time :smiley:
This may be life but just in case I am missing some real simple and invaluable tip I thought I ought to ask the experts :slight_smile:
TIA
Mike
I put the guest on the Left and me on the Right. That makes “by hand” editing a bit easier.
If it’s not too bad, you can use Effect > Noise Gate in your voice to suppress the trash. You’re not reading for audiobooks, so nobody is expecting studio quality. You may get away with it.
https://wiki.audacityteam.org/wiki/Nyquist_Effect_Plug-ins#Noise_Gate
Split tracks also allows you to use Effect > Auto Duck to make the guest track control the host volume.
https://manual.audacityteam.org/man/auto_duck.html
Do you have the lavs placed correctly? They should be just inside the chin shadow and have the strain relief loop with the surgical tape. I had a picture of that…
Here they are. Surgical tape sticks well and then comes off. Click the pictures.
