Thanks for the program, so far. Problem: I can get an external USB mic to record on my laptop but not the internal. Nothing but the thin blue line.
Now, why would I ever want to use the crappy on-board mic when I can use my $600 condenser tube mic? Answer: Curiosity. Also, it would be a lot more handy as I learn other aspects of the program.
I’ve tried all different setting combos for audio hosting and mic settings with same negative result. Even tried switching around in Control Panel and Preferences
Using Audacity 2.1.1
Downloaded with .exe installer (pretty sure)
Windows 7
Take a look in the “Recording” tab in the Windows Sound Control Panel. You should see bouncing green meters when the mic is working. If Windows does not hear the mic, then Audacity won’t either.
Oh, man . . . Just noticed my new laptop actually has a mic on/off switch right on the keyboard panel. The Count is embarrassed. But for some reason front panel switch does not register its status in the control panel.
