Installing acx plug in
Hi Guys,
I get this error message when trying to install the plug-in:
can someone help?
T
ACX-Check.ny (4.4 KB)
That one from my library should work.
You are trying to install ACX-Check(2).ny. That’s the wrong file.
If you’re trying your hand at audiobook reading, do you have the Audiobook-Mastering-Macro?
You can try to struggle with setting the volumes and loudnesses yourself manually, but this is a lot easier.
I looks to me as though you are trying to Import the plug-in, when what yo need to do is install it (Importing is for audio files not plug-ins)
And to make installation easier there is now Tools > Nyquist Plugin Installer - please see:
https://manual.audacityteam.org/man/nyquist_plug_in_installer.html
Peter
Oops. Coffee deprivation.
