Hi
I have using different versions of Audacity in a couple of year, and I am very satisfied. After installing everything on a new hard disk after a crash, I only get a message window when trying to launch program that say:
Unable to execute file:
C:Program FilesAudacityaudacity.exe
CreateProcess failed; code 14001.
This application has failed to start because the application configuration is incorrect: Reinstalling the application may fix this problem.
During installation no abnormal messages appear. Several tries of installation also with different version, and also manual editing/deleting of register components have been performed. The same hardware and drivers for chipset and audio have been in use for a couple of years without any problem before. Os is Win XP eng SP3. If anyone have a tip I will be pleased.
Sten Madsen
