Installation Error/ Config Error
When trying to run Audacity for the first time, I receive the following error msg:
“This application has failed to start becuase the application configuraiton is incorrect. Reinstalling the appllication may fix the problem”.
This is v2.2 using the .exe install verison installed on Windows XP.
Any help would be appreciated.
thanks,
k
See here in the FAQ: http://manual.audacityteam.org/o/man/faq_installation_and_plug_ins.html#probs
