Installation 2.0.3 fails Win XP
I have upgraded Win XP to Service Pack 3 and when I try the Audacity 2.0.3.exe install I get:
“unable to execute file: C:Prog…audacity.exe. Code 14001”
Appreciate any ideas.
Thanks,
Al
The fix is found at http://wiki.audacityteam.org/wiki/Release_Notes_2.0.3 :
You may see the error Application configuration incorrect when launching Audacity after installation. This mainly affects some Windows XP or 2000 machines. This can be fixed by downloading and installing the appropriate Microsoft “Redistributable Package” as follows: Microsoft Visual C++ 2008 SP1 Redistributable Package (x86) for 32-bit Windows
Microsoft Visual C++ 2008 SP1 Redistributable Package (x64) for 64-bit Windows.
It’s also in the “Frequently Asked Questions” http://manual.audacityteam.org/o/man/faq_installation_and_plug_ins.html#probs
