Inserting new tracks at location of choice
Is there a way to set the default so that I may insert a new track at a select spot instead of at the bottom of a project? So irritating to have to scroll to the bottom and drag the new track up to where I want it to be. :angry:
I am using Windows 10.
Unfortunately not yet, so I’ve moved your post to the ā€œadding featuresā€ section of the forum.
Thank you! :slight_smile:
Got the same problem, so it would be great to me too!
Note that since this topic was started, Audacity has gained ways to move tracks up/down that do not require dragging. See: Audio Track Dropdown Menu - Audacity Manual
