I’m trying to insert a 2 hour large clip into a 1½ hour large clip and then audacity aborts with a message.
Trying to send the error report fails so I have copied the report into a .jpg and a .txt file and I have attached the files here.
Hi @jkjfd , thanks for your report!
We can’t reproduce on our side. Could you create an issue on Issues · audacity/audacity · GitHub ? You’ll be asked to describe the steps that get you there, which could help us devs.
Thank you!
