Insert Record Feature
please add Insert record
the ability to insert in the middle of the timeline instead of adding to the end of the track
kind of like punch in and roll record but without deleting all audio to the right of the play head
this would cut down from instead recording to a new track and cut and pasting it in
And the only problem with that is the sudden need to actively manage all that right-hand work—screen video and sound—in real time—while recording perfect quality new sound.
We’re having troubles now with some of the effects which need real-time memory that may or may not be available when needed. If you have a spinning metal hard drive, you will not be pleased with the intermittent delays that will cause.
I think it’s a grand idea, but I also think there are practical limits.
