I have been recording LP s for over 15 years. Now, all of the sudden it seems like a single track (example one vocalist’s voice track). I know the problem is not the turntable as I have tried others and get the same result. Did I inadvertently change a setting in Audacity to cause thi?s problem
Make sure Windows “Enhancements” are turned off.
If that’s not the problem tell us about your hardware setup.
Does the turntable plug-into your stereo so you can check the analog playback?
Assuming If you have separate left & right connections, try unplugging the left & right separately while recording to make sure one side at a time goes silent. And/or if anything “unexpected” happens.
