Input Device
For my Audio Cassette to MP3 converter I need to select Microphone Array (USB PrP Audio) as the INPUT DEVICE for the converter to work. For some reason the pull down menu for INPUT DEVICES does not include this as a choice. Please advise me as to how I can find Microphone Array (USB PrP Audio) as a choice for INPUT DEVICE> Thank you.
If Windows sees the USB device, choose Transport > Rescan Audio Devices from the menu at the top of Audacity, or restart Audacity. Audacity cannot see the USB device if you plug it in after starting the program.
If Windows does not see the device, the usual solution is to change the USB cable to one that works.
Gale I certainly do appreciate your assistance. If you was here I would hug your neck.
